Coker wheels
al pa.
Anyone using Coker dual pattern wheels?I need 6 inch wide,15 inch wheels,for 5 1/2,and 4 3/4 inch bolt circles,and 3 inch backspace.I get bumped out before getting my zip code in the on line order form,and probably won't get a catalog.May need to phone them.Thanks
Unrelated to the question, but I read where Coker has bought Wheel Vintiques. The article said he will continue to operate the business under it's present name in addition to his present wheel line.
I have dual pattern Wheel Vintiques wheels on my car for 17 years, no problems.
I have vintiques dual pattern for 10 years.Mine are tubeless and they are spoke type.Had some trouble with leaks at the rim spoke area sealing.Found the cause was porosity in the sealer to seal the spokes at the rim.I found the porosity with soap bubbles.Using a course
burr i opened up the area and replaced it with GE bathtub sealer.No additional leaks after 30,000 miles Lee34
we bought a set of 16 X 6 wire wheels with 4 1/2 & 4 3/4 bolt patterns. We had them powdered coated, they came out beautiful for over $450 apiece. We had to use tubes. They are also very heavy.
Are they by any chance 5 1/2 and 4 3/4 bolt circle combonation?That would be outstanding news.
Yes they are. But do yourself a favor and google Wheel Vintiques. Also, any aftermarket wheel needs to be spun and checked for true before you paint and mount tires. Save yourself some pain.
al,
Just for a comparo...try Summit in Ohio. I'm very happy with my wheels....
not sure but I think they sell Stocktons....
Charlie ny
You can also try Wheelsmith in the L.A. area or Rally America in Fresno, Ca. Not sure you can get the dual pattern with 4 3/4and 5 1/2.
I bought dual pattern Wheel Vintique wheels from Summit and the b.c. are 4.5" and 4.75".
Bob
