Took resistance measurements on the coil. 0.6 -0.7 ohm low side and about 8500 on high side. Is this in the ballpark? Like I said, 5.4 volts reading at battery side of coil with ignition switch on. Guess the next thing I’ll try is direct wire from battery to coil.
