The wire to the coil usually originates from the ignition switch. Main feed wire to system usually starts at the solenoid.
A diode is designed to allow current to flow one direction only and would have to be connected correctly to get it in the right direction and it would act as a cold start device if connected at the starter terminal.
Kerby
