419scubadoc
New member
What voltage should be read from top coil terminal on stock 1940 engine?
If points are open, there is no current flowing, therefore no voltage drop across resistor, then you would read the full 6V at the coil.I think it depends on if the points are closed or not. I would make sure the points are open before checking the voltage. Seems like I read that someplace.
just as an aside...
a voltage drop below 6v would play havoc with a 6v ELECTRONIC ignition system that depended on 6v to work properly, i would think.
