Gentlemen,
I have 2 (NOS) Coil Resistor Circuit Breaker assemblies for my 41 truck. Both came in boxes labeled 01A-12250. However looking thru the perforated metal cover over the circuit breaker portion there appears to be an obvious difference. One has a few turns of heavy gauge copper wire wrapped around an iron rod. I assume that a "short circuit" overloads the thermal contact and it will "open" the circuit.
The other assembly does not have the coil but has just a thermal contact.
Is there a difference in part number, like a revision, and will both function properly, assuming the parts are not defective?
Thanks for the help.
