gkgeiger
I was reading through my V8 Times and got to the Tech section where I read about the markings on a tube style coil. The person asking the question had a 51 Crestliner and was going to replace the coil. His old coil had Bat and Dist for terminal markings. The replacement has + and - as does mine. He asked if the + marking was the same as Bat on the old.
Cecil's response was "Assuming you still have the factory positive ground system on your car, the "+" terminal should be connected to the distributor and the "-" terminal should be connected to the ignition switch. In other words: Bat = Negative and Dist = Positive."
I connected my new coil "+" terminal to the ignition switch. The car starts and runs fine. Could this be why my original coil failed? Should I switch the wires, or?
