I am no wizard on coils, however I found that I needed an external 1.5 ohm on my 12 volt neg ground 1.5 ohm coil or it got very hot if the key was left on when engine was off. I used a bypass type starter soleniod so I have the full 12 volts when cranking and the resitance added when the eingine is running or not.
Would a 1.35 or 1.82 ohm resistor work for a 12 volt system??? Can't seem to find a 1.5 unless some one has a Napa part number.
