I just checked it out. $69.10 CDN? Even accounting for the exchange rate that is pure BS. Someone screwing around with the price or am I a day late and $39 short?
Tried to buy four but unfortunately they will not ship outside US.
All just seen the Bosch Blue coil #00012 on Amazon for $22.08 usually $61 . Better act quick , i have never ever seen a bad one doesnt need a resistor when used with 12 volts, resistance is wound in the coil.......
www.amazon.com/Bosch-00012-92200810...7956172&sr=8-1&keywords=00012+bosch+blue+coil
Better get it , wont last long....![]()
Amazon uses dynamic pricing that will fluctuate based on supply and demand. You guys caused a spike in demand that bumped the price up.
I have seen the price on an item shoot up just after I viewed it on line several times before buying. They must know when I looked so they upped the price for me hoping to create the thought that maybe I had better buy it before it continues to go up. Doesn't work on me. I went back several days later and the price was lower again.
Will this coil work on a 6 volt system?
Will this replace a Pertronix Flamethrower??
Thanks for the post. I bought 8 of them. So tired of failure of the coils, condensers, voltage regulators, etc. that come from the parts house. Is there a condenser that is the best match for a crab? I have a Napa IH200 now.
Sure, why not? Now, it's a 3 ohm (primary) winding coil. Normally used with 4 or 6 cylinder engines. BUT, it should work slick to run in a system that has either removed or bypassed the external resistor or ballast. I was thinking as a spare, in case the Pertronix Ignitor fails on the road. Just install points, Bosch coil, condenser and should be all set for as long as required. As you may know running points without about 3 ohms resistance in the primary circuit will roast the points quickly.
Maybe Bubba can speak to this, what they did in the 12 volt days was split the 3 ohms primary resistance, between the coil and the ballast, whether a wire or ceramic unit. While this reduces the voltage and is what people talk about or often measure the reason for this is to reduce the current flowing, through the points (or solid state module), they will burn up with too many amps.
