Pa Joe
I got a bran new coil from FSI to go with a 12V negative ground Electronic distributor. In FSIs instructions it says the coil should read 3.0 to 3.5 ohms. Tested with a very expensive digital tester it tests at 3.7 ohms. First question, is that a problem that it's over 3.5ohms? Might add the coil was a little damp on top right out of the box. This contradicts the info in Les Andrews Vol. 2. It says 3.5 will run but with weak spark. Anyones thoughts on this would be appreciated.
