Coil Box Switch
Rowdy
I loaned out my Bruce McCalley book so I can not look this up, but I need to know whar years this swtch is correct for. Thanks Rod
If that is a composite switch body, the face plate would be blued and could be used on a '16 & '17 - a bit hard to distinguish from that photo. I believe the full steel switch cover went into production after that time frame.
Here are the rest of the pic's. May be alittle clearer. Thanks Rod
Thanks, I will have a better look at this when I have all of the coil box stuff infront of me. Other than the switch itself everything is 25 miles away. As long as I can make one work right and it has the correct cover I might not be too picky from there. Rod
