Woodie1
I put a touring engine in our Model A 3 years ago. I have about 10,000 miles on it now. I need to replace the clutch disc & was wondering what thoughts were about the pressure plate. A V8 plate was used instead of the model a pressure plate. I'm thinking the plate should be good yet. I believe when I installed the new engine I did not make a clutch adjustment so I may have worn the disc prematurely. I also wonder about the free play in the clutch pedal. Should I feel the 1" when pressing the clutch pedal after I make sure the throw out bearing is not touching the pressure plate fingers?
