Hi,I have a 1949 Ford 226 inline 6 cylinder engine with a 10 flywheel and 10 inch clutch pressure plate. The engine is mated to a 1934 Ford V-8 transmission. The factory 1934 Ford throw out bearing and bearing collar assembly on the transmission appears to comes up short ( 3/4 inch) when I try to depress the clutch to disengage the engine from the transmission. Does anyone know what throw out bearing collar I need to make up the distance between the bearing and the pressure plate fingers? Thanks for any help, Don.
