Chuck Sea/Tac
If you have the flywheel refaced, the place where the pressure plate bolts has to have the same amount removed. The factory spec is .123” as I recall. I’ve seen them work “off spec” but why not do it right.
Also check the U Joint - very likely worn since all seems to be original equipment.
Like this?
Swapped that out a while back when I first put this engine and trans in.
Found my spare pressure plate. Has a very light score on it and a little surface rust. I can scotchbrite the rust off easily enough. Any thoughts on the condition of this one? I know ideally I'd just replace it, but £185 isn't insignificant and if this will work just as well, I could spend that money elsewhere.
the head just pops loose.
I got the flywheel and pressure plate back from the machine shop.
I cleaned the carbon off the top of one piston and found it's already 0.070" over. Bore gauge showed an additional 0.0165" clearance in the bore. So rebore and bigger pistons.
Babbitt on one big end had crumbled. So new con rods to go with the new pistons.
Then I noticed this on the centre main:
Crank has to come out anyway so I kept going:
And that's where I'm at. I'm on the trail of a newly rebuilt engine fully converted to insert bearings. Pretty much the same cost as getting this engine done, so that's where I'm heading.
Moral of the story: don't look!
