Does anybody know where I can get the bushings (if that's what you call them that go on the ball of the clutch shaft--two little half-round clamshells. Proper name for them? Where to find?
I got mine from Van Pelt's, IIRC. They make a composite bearing in addition to the copper/bronze. I was told the composite is better. Sorry I don't remember the proper name.
Edit: Clutch release equalizer shaft bushing. Carpenter advertises them.
We’ve got them in stock, as well as the little rubber washer and the spring that both work with the split bushing. Unless you can find it as NOS somewhere, I’m fairly sure that the nylon bushings are all you can find these days. I think they hold up better than the bronze bushings.
The white plastic bushings were used in the 70's thru 90's in F series pickups. They should be easy to find if you look. Grease it once when you put it in and it should be good for life.
