Bassman/NZ
Further to my thread "I'm stumped", I managed to unbolt the clutch cover by removing the flywheel cover, and removed the trans. I discovered the clutch is an 11", which I dont want to keep as it's going in a light AV8. The plate is frozen on the input shaft at present, but my question is.... will I need to change out the flywheel to install a 9" clutch? ie: do all clutch covers have the same bolt pattern?
Thanks, Marty.
Thanks, Marty.
