I have a 1930 Victoria, 1947 Flathead, Speedway adapter for a Chevy S-10, T5 transmission. I recently pulled the Transmission to check on a "chatter" in the clutch and found nothing wrong (ie: no fluid or subsatances on the clutch disk, etc. Now I can't get the clutch to engage properly. I have replaced the slave cylinder, adjusted the push rod of the slave, bleed the master clutch cylinder and slave countless times. I can start the car in gear and the clutch seems to work but if I start in neutral and try to shift into any gear, it won't go. If I adjust the push rod to its max and push the car in gear slowly while depressing the clutch it will engage and the car will move but as I continue to depress the clutch it will disengage as the clutch pedal nears the floor. HELP!
