well this past winter I removed the transmission too find a noise in it & did! I completely rebuilt it now it works fine. after got it back in the car the clutch has started acting up. I have about one inch or so free travel at the top! as it should be, but it is not completely releasing, it wants to grind the gears when you shift from first to second & second to third. setting still you can shift it with no grinding, it is the same clutch & pressure plate & throw out bearing that was in the car, nothing was changed on the clutch to cause this. the only thing I can see that is different it the clutch pedal is two thirds the way out before it starts to engage! it used to engage about half way out. It don't make any sense to me? any body got any ideas?
