Tom Endy
Roland:
Sometimes you just have to take everything apart and carefully inspect everything. I would inspect the clutch disk carefully. According to Les Andrews' book the thickness should be a nominal .340". Check the outside diameter and the diameter of the inner metal hub to make sure nothing is binding. You may have a disk that is not correct for a Model A. If you are using the original Henry clutch set-up check the dimension of the flywheel step the pressure plate sets in. The measurement should be 1.123". If the clutch surface has been machined a number of times the dimension may have been lost. Check that the springs in the clutch disk are not rubbing the heads of the flywheel mounting bolts. This is caused by a flywheel that has been resurfaced too many times. You can sometimes grind the heads of the bolts down somewhat to provide clearance. If you are running a V-8 clutch set-up there are other things to look for. See the article on V-8 clutches on the "tech Articles" page at www.ocmafc.org.
Hope you find the problem.
Tom Endy
Tom Endy
