bmodeltman
Are there different clutch pedals? I'm putting the car together from.parts and the clutch pedal hits the engine mount before it gets to the stop on the shaft collar. The clutch will not disengage. The clutch is new and adjusted fingers to 5/8 from top of.pressure plate. The clutch arm.isnt cracked. It has the correct throw.bearing hub. I have 4 inches of travel till it hits the engine mount. I have the one inch of free play so I only have 3inches of actual pedal pushing pressure plate.. Checked.the pedal with another and it doesn't seem bent. I did search and found something about a later pedal. This is my first A . I'm more familiar with the model T
