Roxo
I recently Picked up a 1937 Ford Tudor Humpback. My problem is the clutch pedal sticks when releasing it, when in gear and the car running. About the time the clutch should engage the pedal stops. That's about 85% of the time.
I replaced the clutch plate, pressure Plate, throw out Bearing and pilot bearing. New spring and fork. New Pedal return spring. No change.
The pedal works fine in all gears when the car is not running. I have greased and oiled up everything I could find. Could it be in the trany?
This is my first V8 flathead. I have never encountered such a issue with my Model A, that has the V8 clutch.
Any help would be greatly appreciated thanks Roxo
