Anteek29
My '55 Vic's clutch pedal does not smoothly return all the way back to rest position. It hangs up a bit and then I have to nudge the pedal up to the stop by lifting my foot underneath the pedal. Looking under the dash I see the big return spring connected to a threaded rod which then connects to the pedal arm. Adjusting the threaded rod seems to have no effect. Other than facilitating installation and removal of the return spring, what is the purpose of the threaded rod?
Note: The threaded rod is not the same rod which goes down to the clutch.
