Will N
I was checking the adjustment of the clutch pedal the other day. I found that the pedal is loose on the shaft. That is, it will move maybe 15 degrees before the shaft starts to turn. That can't be right, right? I imagine that the hole in the shaft for the drift pin has ovaled over the years? Or, is there supposed to be some play in the pedal on the shaft so that it will release the clutch before it starts to tighten the low speed band?
