i have a 47 flathead v8 with a T5 from a mid 88's mustang and a trans adater from wilcap and sharp. i'm using the stock pedal set up from a 51 f100. my question is, how do i hook up the trowout bearing return spring. do i put one on the pedal to pull it back or do i put it on the clutch fork. also did'nt ford make a thin spring that looked like a piece of wire that held the fork to the throwout bearing. thank you, grizzly.
