40cpe
On a '55, is there a bushing supposed to be at the pivot point of the clutch pedal arm and the rod going through the firewall? The hole in the rod is "D" shaped and larger than the pivot bolt shoulder. My searches don't find any reference to a bushing, only shaft bushings. What is it called and source if possible?
Also, should there be a spring keeping tension between the arm on the throw-out fork and the rod that actuates it? If so, where does it attach on the forward end. Thanks for any information.
Gene
Gene
