I haven't had to do it with a Model A, but my 52 pickup had the disc rusted to the flywheel a couple times. I started it in low gear and got it going down my long driveway a few mph then held in the clutch pedal and bounced my other foot on the throttle pedal a few times to get the old truck bucking a bit. Came right loose, no messing around.
Jack up the rear wheels and place rear axle on jack stands. Make sure the path in front of the car is clear. Start the engine with the car in high gear and speed engine up to fast idle. Hold the clutch pedal to the floor and jab the brake pedal hard a couple times.
I’ve used this method three different times, and it worked for me. Make sure you can do this safely.
W.Michael
Finally had a change to pull the engine and transmission. The clutch disc is completely stuck. I tried to loosen it up by using a rubber mallet but that did nothing. Any ideas of how to remove this?
Denny
