Question for you folks. I have just gotten my recently acquired 31 started after it has been sitting for many (many) years. Tonight I got it idling very nicely and now little to no smoke. Great!
However, after it had been running for about 20 minutes or so the clutch (which had been working fine up to that point) doesn't seem to want to work any more. It feels fine but it won't let me put my car in any gear. My thinking is that, once everything warmed up, the clutch engaged with the pressure plate and then froze up against it so now it won't disengage.
Does that make any sense at all? Is there anything I should check to that may be a simple fix?
It worked fine right up till tonight. I was able to put the car in gear and drive it forward and back without a problem. This only happened after it had been running for about 20 minutes. Thoughts? Suggestions?
By the way - my cars body has a serial number of CAS2897 and engine is CAP2149. Is there anywhere I can look that may tell me a little bit about the story of my car - when it was made, where, sold when, etc.
TIA
TIA
