Clutch fork pivot bracket loose - repair help
wga
Ref 49 bellhousing - see attached photos.
The two rivets, one is loose the other's head is broken.
What are your thoughts on welding the bracket in place vs. riveting or
flat head cap screws with metallic locking nuts.
I would rivet it and then tack weld the rivets. Would also put a small weld on each end of the bracket.
