A amishman Member Nov 17, 2020 #1 Les Andrew's book says the depth of 5/8 of an inch for clutch finger.What should the V8 clutch depth be for the Model A be set at?
GRutter Senior Member Nov 18, 2020 #2 The same. 11/16 should be the nominal measurement for both Attachments clutch-adj.jpg 73.6 KB · Views: 39
S sofield Member Nov 19, 2020 #3 Is the 11/16 measurement with the plate and disc bolted to flywheel? Thanks for a response.
Patrick L. Well-known member Nov 19, 2020 #4 sofield said: Is the 11/16 measurement with the plate and disc bolted to flywheel? Thanks for a response. Click to expand... Yes. The fingers should be .002" of each other.
