1930 roadster
Clutch does’t work.
Hi guys,
I’m blinking new on this forum.
Read a lot of post though.
But now I’ve got a question that I have not seen in any of the posts.
The books by mister Les Andrews could not help me.
I bought my model a roadster last april.
My roadster never felt smooth when shifting gear.
I always double clutch. But lately it doesn’t shift at all.
Gears grinding etc. last time I drove it, I had to abuse the gearbox to get it in first.
When I looked into the little hatch op top of the bell housing, I saw the throwout bearing spinning while in neutral and no clutch ingaged. Not a good sign
I thought it had to be the clutch disk. Why else would you set the clutch this tight?
I pulled out the back axle, gearbox and clutch. Turned out nothing to see.
The previous owners did a nice job. Everything new or well preserved.
Clutch disk looks new. Checked the thickness….. must be new, over 9 mm thick.
As everything was out, I changed the throwout bearing.
Put the clutch disk back in.
Then I thought is could have been the fingers on the pressure plate.
Put the pressure plate back and set the fingers.
Put the gearbox in. I left the back axle of, to save me some work when my efforts did not work.
With the clutch fully engaged and first gear the axle won’t turn by hand.
I tried the starter. the axle turns with the clutch fully engaged.
Only thing I can think of is that clutch engaged, the axle needs some counteraction from the rear axle, to see if the clutch works. Am I right?
Otherwise I’m out of options.
I don’t think it has anything to do with the pressure plate. If the springs are worn out, the clutch would slip. In my case this seems to be the other way around.
Is there anyone who can point me in the right direction?
Thank you.
Hi guys,
Thank you.
