Steve Rinaldo
I am looking for the following measurement specs.
1. On the flywheel measuring from the pressure plate mounting surface to the clutch disc surface. I have read that the most common number is 1.125. Is this correct?
2.The distance from the top on the pressure plate to the top of the actuating fingers. The most common that I have read is 7/8. True
Thanks, Steve
Thanks, Steve
