Clutch Adjusting Yoke
rfitzpatrick
I've ordered Brattons Part Number 11361 -- it's getting difficult for me to get down!!
Anyone using this item plz? I'd post a photo, but don't know how.
Tks
Tks
Yes, works great. Makes it easier to adjust the clutch. No need to pull pins.
Getting back up is the issue.
532347
Hydraulic clutch linkages are self adjusting. Has anyone installed a hydraulic clutch linkage in a Model A?
Here's an overview of the replacement adjusting arm.
Is the threaded portion strong enough to hold up (and not snap) over the long-haul? Thee (original type) trunions sometimes snap, and the car lunges forward with no clutch. The owner needs to quickly turn off the ignition to keep from hitting the car in front of them.
I have had mine installed for ~9 years (9/21/2014 to be exact) with no issues.
has anyone ever used one of these fully threaded units on the multi-disc clutch? I was recently disappointed when i noticed nobody sells a pre-Nov '28 version of this part - nor do they tell you in their catalog that what you're buying won't work on those cars.
Actually I'm having quite a rough go at this -- working alone. I first installed Brattons Clutch Release Shaft - Brattons P/N 11270. Now trying to mate this to Brattons P/N 11361. P/N 11270 is a tad longer thn original/ This is not a one-man job by far.
Has anyone used theses to P/N's together?
Yes, those are the exact parts I am using. No issues. I like the longer Clutch Release arm as it make it a little easier to push the Clutch Pedal.
