runmikeyrun
So I’ve got a cluster voltage regulator like the one pictured on out ‘42 Ford. I have my +12v coming into the single terminal, and the dual terminals feed the gauge cluster. It’s powering three gauges total- the fuel and temp are in parallel and the oil pressure is on its own. When I turn the key on I get 12v on both terminals, then a second later it shuts off. It will only reset if I turn the key off. I’ve tried adjusting the screw in and out, no change at all to the voltage. I’ve tried reversing the leads and no change. I’ve tried grounding directly to the frame (was only grounded through the cluster before) and still no change. Any idea what is going on here? I opened up the regulator to check the internals and everything looks ok.
(Note- when I uploaded the picture I noticed that it says “ign” next to the double terminal. It appears I’ve had it hooked up backwards- could I have killed it doing so?
Thanks in advance.
Thanks in advance.
