cluster light socket high beam
cvicky
my one wire high beam socket is missing
the hole in the back of speedo is about 5/8" but very shallow
any ideas where i can get something ?
Any parts store will have the socket which is more a less standard. Then you need a
#51 6vt bulb now you just have to find the feed wire very odd its not there??
... now you just have to find the feed wire very odd its not there??
If it helps...
I have wiring diagrams for a '55 and '57 (T-Bird),
on both the power wire to the high beam indicator light is Green with a Black stripe.
i'm confused? the wire has to be there, or somebody been in there. Whatever color
wire; comes from the high beam terminal on the foot switch. I think all you can do is
run a wire from foot switch to the high beam on the cluster. Or you open a can of
beans cutting the wire harness. It maybe broken or cut at the harness break out. the
break out means when a wire terminates from the harness...
That is a unique and oddball looking light socket too BTW, since it is a deepwell type so the bulb sticks way into the hi-beam well. Kinda looks like a cigarette with a washer around it. Look around under the dash, maybe it is just hanging in there somewhere.
