After considering all advice, I think I will be better off to stay with the original closed shaft set up. My setup in my 1939 Ford pickup does pretty good(it jumps out of gear some). I was able to obtain a top load transmission that looks to be a 1948. Previous owner took it apart because some gears are chipped and never put it back together. I would now like to rebuild it and have it as a backup for my truck. Besides damaged gears, what parts do I need to change out. Where can I get the used “Main Shaft Bearing Retainer” #78-7085 B? Thanks for the help.
