Closed car mirror position
christobal
Hi,
I'd need to know what is the correct position of the original rear view mirror (type D as per judging standards) in the Tudor closed car. I thaught it had to be right in the middle of the windshield header but this is not possible because of a screw already there for maintaining the lower sheet metal of the windshield header.
What should be the distance of the mirror to the windshield header center ?
Thanks for my French Tudor.
Jean
You are correct. The mirror on my '30 Tudor is not in the center, it is slightly off to the drivers side. I have the same "Style D" Mirror assembly.
I am not sure if all years were the same.
If nobody responds by morning, I will try to remember when I go to my shop tomorrow to measure my car and get back to you.
What year do you have?
Chris
On my S/W sedan, the location of the mirror mounting screws is determined by some notches in the metal header. There is also an extra notch to allow the mirror to be on the other side for RHD cars!
So the real question is: what is the point of it being off-center?
Doug
Doug
Being a little closer to the driver gives a better field of vision. As an extreme example think of the outside mirrors mounted on fender well spare tires. Even if they didn't shake you still couldn't see much with them since they are so far away and limit the field of vision.
Hi Fellows,
So many answers in one day!
Nevertheless I will really need the offset distance between mirror center and windshield header center because my metal header doesn't have any notches to indicate me where to screw that mirror.
Thanks
here is a picture of my original 30 tudor sedan
there are no other holes
it is dead center of the header
the two bottom holes go through the two holes in the metal
the upper hole is in the wood block
tom
