Although these clocks can be repaired you may want to consider doing a quartz conversion. (http://www.clockwks.com/Quartzx.html)
Not sure how they power theirs but I converted my own and it is powered by a yearly changed AA battery.
All the visible attributes are stock looking.
They have points? Have to admit I've never seen the inside of mine on the 52 and am afraid to open it up as I'll either break or lose some important part. At least it looks good and original even if it does not work. Still lights up.Quick update: filed the points and good as new.
Yes indeed, they have points.They have points? Have to admit I've never seen the inside of mine on the 52 and am afraid to open it up as I'll either break or lose some important part. At least it looks good and original even if it does not work. Still lights up.
Thanks for all the info and pictures. It makes a little more sense now but I think for the time being I will be satisfied with the clock as is. At least it is right two times a day.52 MERC-CT,
RalphG,
They are well built clocks, so nothing should fall off once the back cover is removed. I usually do everything on a card table next to a well lit window[/url]
If you haven't opened one up give it try, they are amazing to watch. With all of today's technology it is like watching the past come to life right in front of you.
Did you remember to set it for Daylight saving time?Thanks for all the info and pictures. It makes a little more sense now but I think for the time being I will be satisfied with the clock as is. At least it is right two times a day.
This is Saskatchewan. We don't bother with that DST business. Same time all year round.Did you remember to set it for Daylight saving time?![]()
Every year, twice a year I read comments on the net of people complaining about the hassle of adjusting clocks and having to lose an hour of sleep. Meanwhile I sit here wondering how they manage to get 25 hours out of a day. The simple life here.Why - does it upset the cows?
No worries there. I am a big fan of keeping it original, as much as possible. Mine will remain intact in the dash and at least look good.Please avoid converting to quartz. Once these original clocks are gone, they're gone. Do not be afraid to take your clock to a clock/watch repair shop. There is something special hearing the click, click, click on an original clock.
