Clear Distrubutor Cap
Yes I just looked at both of mine and have the same crack in them. One is worse than the other.
After two weeks I still did not get a bill.
ctvpa, The one I have with the Ford script is plastic. The one I received from Mike's during the weekend sale, appears to be cracked in the radius between the cap lid and the wire tower. Do any of the three you received, have this flaw ?
To all,
The one I got and placed on the car is perfect. However on this post, along with the other post reporting problems, I inspected the other two that I bought, and indeed, they have a crack.
I apologize if my recommendation of this product has caused anyone inconvenience.
Craig
If anyone has a clear cap purchased from Mike's that they feel has a problem, I would suggest they give Mike's a call. I just talked to them, and I can assure you they were more than helpful in resolving my issue of the clear caps. We are fortunate in our Model A community to have nearly all of our major distributors that set the bar for integrity.
I've got two from Mike's and they seem to be fine. Even with a crack that you can hardly see shouldn't effect their performance. They are a novelty after all.
I agree. I cannot even feel the crack, it might be within the plastic, but it works. For less than $10 I can't complain
I have a clear cap from Mike's with no flaws, but I only use it to check my spark since I use a modern cap from Snyder's. Does anyone have a part number for Napa or O'Reilly's for the modern caps? I have a hard time justifying 14.00 shipping from the parts houses whenever I feel the need to replace mine.
