hardtimes
Muriatic Acid (AKA Hydrochloric Acid) will dissolve rust very well. It will also dissolve a radiator. I have reservations about using it on engine blocks for two reasons: 1) cast iron is porous and you may not be able to fully neutralize the acid, which may continue attacking the sound iron, and 2) there is this thing called hydrogen embrittlement due to strong acid exposure which may lead to more cracks in the future. Maybe somebody familiar with metallurgy can comment about the risk of hydrogen embrittlement from the use of Muriatic Acid on iron castings?
X -TWO !
I've experimented with muriatic ! I would never use this STRONG caustic acid in an A/B block for exactly the words/ideas that you've expressed. Additionally, this acid IS dangerous/injurious if used wrongly and /or accidently. As stated by others, the rear of the A/B block is inaccessible to a large degree and , IMO, where a guy will find the most compacted rust. Ergo, you need something that WILL consume that rust totally/safely (to you and to block)....and that needs no neutralizing ! As I wrote previously, I've spilled Evaporust on pavement, on my clothes/boots and on my bare hands....with NO negative impact. Subsequent to my first writing, someone asked does it desolve other metals, i.e.-good solid metal and radiator. Well, in answer, I say that I studied every written bit of information that I could get my eyes on, prior to trying this product. NO, it does not attack other than rust ! Given enough time, it desolves rust in whatever form...AND STOPS when no rust to consume ! Conversely, just try drops of muriatic on cloth, cement, skin...heck, just smell the fumes if dumb enough. To stop its destructive behavior, you will have to have proper neutralizer on hand and let it interact for sufficient time to even stop it at all. It will not 'discriminate' between, radiator, good block metal, rust or your hide
Like said previously , do you own reading /research
