High lift and high lift rate are two different things, I agree the Clay Smith cams arnt high lift, but the rate if I recall was correctly was quite high. Sorta gets up quickly, stays full up quite a long period, the closes quickly. I'm sure that's what my notes says? The cam in my notes is actually a 282-2 which had slightly revised exhaust pattern. Again if I recall, my notes arnt with me though.
Martin.
So that's what the -2 bit comes from, thanks for that.
From Ron's book, 272-2 rough idle but ran good on the street. Also states can be used in any weight car.
Martin.
Guys,
I have a Clay Smith cam (M3) for the “60” engine. Anyone have the specs on this M3 cam?
Thanks,
