Tightening the camshaft nut to 100 lb-ft is not necessary, and is not specified in any Ford literature.
In the Model A era, fastener torque was controlled by using special tools during assembly and 5-Z-XXXX dealer tools afterwards.
The wrench for the camshaft nut, 5-Z-1832, has a 9 1/2 inch length between the center of the nut and where the wrench is gripped by the mechanic.
If the mechanic exerts 50 lbs at 9 1/2 inches, the resulting torque is about 40 lb-ft.
If the engineers at Ford wanted the camshaft nut to be tighter, the 5-Z-1832 wrench would have been longer.
Although the threads on the crankshaft ratchet nut are much smaller than the threads on the camshaft nut, the engineers at Ford wanted the crankshaft ratchet nut to be tighter.
The wrench for the crankshaft ratchet nut, 5-Z-1900 has a 17 inch length between the center of the nut and where the wrench is gripped by the mechanic.
If the mechanic exerts 50 lbs at 17 inches, the resulting torque is about 71 lb-ft.
