clam shell interchangeability
Mark from Australia
I know that it's probably impossible, but can a clam shell from an early production A (multi-pieced brake cross shaft) be fitted to a post-32 transmission?
Model A has six bolts and 1932-48 has four bolts.
Yes, with a little work. 4 of the 'A' holes need to be drilled to 3/8", and 5/16" nuts must be drilled and tapped as if you don't there isn't enough room for a socket. I did this on my '31 pickup when I installed a 'B' trans. I recommend finding a V8 clam shell that is 2-piece.
Thanks for the advice Jim. I followed your written words, and sourced a pair of long-out-of-production B into A float-a-motor mounts, and some pedal and wishbone mounts. A friend of mine was making a centre-mount emergency brake handle mount, so he made two, and the extra was a birthday present - lucky me.
At this stage, I am wanting to stick with mechanical brakes, and rather than replace the cross-shaft, I would like to stay with the multi-piece setup ..... unless it proves impossible.
Mark, I'm into performance A's, so I tried mechanical brakes but didn't like them. I even put mechanical's from a '35 Ford on the rears, that was better but still not to my liking.
My '30 tudor came with float-o-motors but it had a lot of clutch chatter, so put the originals back in place, this helped but the best solution was changing to a diaphragm clutch. (what genius decided to put the 'g' in diaphragm?)
Jim, my car is equipped with 32 front brakes, and they are a definite upgrade on the original. As they work well, it's hard to justify upgrading them to juice brakes.
There is no clutch shudder to date.
You may remember the car when it ran at the FAST time trials in 2018/2019, then modified by the then owner, fitting lowered springs, and 32-34 front axle, perch bolts, brakes, and 18" wheels
If you are using the split, two-piece cross shaft from late 1928 I would strongly recommend that you change to the one-piece cross shaft. The so-called equalizer system with the two piece cross shaft is much more difficult to adjust for proper brake operation, has a lot more wear points, and uses springs at the frame clamps that are not available anywhere that I know of. If you can source a one-piece cross shaft and the frame mounts that go with it you can use the V8 clamshell and have better mechanical brakes.
