Chopped 1949 Tudor
blubyu
New member
Clinton Township
MI
Price
8500.00
Hello everyone.
I am selling a 1949 Ford Tudor for my friends wife. My friend passed 4 months ago. He was a car designer and this was the last project that he didn't get to finish. Left behind a wife and two young children.
Erwin purchased the car from Pennsylvania. He Chopped it but most of the mods were done previously to him buying it. Stamp is on the Firewall and Vin number under hood spring on the passenger side. Car was stored off the ground for close to 9 years.
It's a straight Chop, The C pillars around the back window need to be finished. This car will look sweet after some metal fab is done to complete it.
Original Engine and Transmission
3.75" Chopped but not finished.
All original Glass/ one piece has a crack.
All Original Chrome/Window Bezels/Mirrors
Complete interior minus carpet and headliner in good shape. (clean up and use it)
All Hardware for interior and exterior components bagged and tagged.
Windshield Wipers / Side Door Mirror/ Window stainless Bezels/Window Int Moldings
Dual Exhaust with Glass Packs
Headlights and Tail Lights work
Gauges on Dash work, Monocle IP in excellent shape
Needs front floor Pan
MAGIC AIR- Was not tested \ Heater was not tested either.
3 Speed Transmission Overdrive?, I did not see a Solenoid.
Original Radiator, May have been re-cored.
All lights work
Glass Pillar lenses for interior
Upper Rad hoses in good condition lower Rad hoses show age.
Radio has not been tested, neither has the clock.
Offenhauser High Performance Intake on the engine
Clear High Pressure flexible fuel lines going to the carb and fuel pump
2 Stromberg 97 Carburetors on the car
Master Cylinder moved under the floorpan DS.
Original Starter
Summit Racing Portioning Block on the frame DS.
Dynotech Driveshaft rated up to 700 hp.
Bullet Spider Style Center Caps (4)
2" Lowering Blocks on Rear Axle
JAMCO 1949-53 Ford Deluxe Ultra Cruise Kit
Disc Front Brakes
Coil Over suspension
Bob Drake Sending Unit
LOKAR'S accelerator Pedal
LOKAR'S Emergency Brake
Brown Distributor Cap.
Brand New Steel Town White Wall Tires
Stored indoors.
Included
Original Ford Intake # 8BA 8RT 8520
Original Ford Holley Carb / Chrome Air Cleaner
Original Spare Tire
MASTER POWER BRAKES, Power Brake Booster/ MC
MPB Vacuum Hose Kit
MPB Boot and Plate
Tail Lamp Frenching Buckets
Battery Cut Off Switch
Pertronix Electronic Ignition 447-1282
"RUNTZ" Dash Voltage Reducer
Trayer King Pin kit
New Rubber Transmission mount
Chrome Grill Knobs for custom Grill
UNI-SYN Synchronizing Tool
4 Ton Hydraulic Bottle Jack
2 sets of Used Spark plugs, (Bosch, Autolite)
Dennis Carpenter Cowl Lacing Kit 704-786-8139
HOLLEY Fuel Pressure Regulator
Felpro 239 Flathead Gasket kit FS 7525 B (30667)
Car is also running smooth. I installed a new Battery, Negative Battery Cable, Autolite Spark Plugs, VR1 20W50, New Carter Fuel Pump and blew out the Fuel lines.
Car was stored with a full tank of gas. This is a nice rust free car. Clean Title.
Photos
https://www.dropbox.com/sh/haaqmp0t2cj9qma/AABQ7kprRGTX8gZWy4vbtYW_a?dl=0
PM me if interested. 8500.00 Obo.
Chris
