Yes, you can use 283 Pistons with a little machine work, ...however there is not a real advantage IMO. The wrist pin size is different, the Chev. pistons are heavier, and you lose a little compression into the piston's valve reliefs. The only gain was the narrower ring. If you are looking for a performance piston on a budget (less $$ than custom made), then ask Rich Falluca about his new piston.
