d.j. moordigian
While doing some research on my B engine build, I found I have a number of questions.
With the crank offset .125" and a "stock Chevy piston" having a .060" offset
pin. Which way are you guy's installing the pistons,..arrow to the "front" or
to the "back"?
Now that Rich at " Antique Engine Rebuilding" has correct rods for the Chevy
pistons,...which corrects the "compression distance", that's a NO BRAINIER.
But were still back to the stock Chevy piston with the offset pin. Same question as above!?
Back in the 60's we used to change the piston direction too change the torque characteristics of the engine. Just an aside..
Since I have stock B rods and pistons ready to go,..I'll probable use that
combination. But if I didn't,..Rich's rods with custom pistons( with no valve
reliefs) and a proper ring set-up would be the way to go,..and you don't
need to deal with the offset pin bore problem..
So,..are we reinventing the wheel?...or making it better?....or making it cheaper?
to the "back"?
