I found a very minor gas leak around the steering column support bracket in my newly restored pickup. It has 800 miles on it. The tank was acid striped, sealed and painted. I can see a crack off to one side of the bracket that is very narrow and less than one inch long. I hate to remove the tank but will if needed. I was told some have successfully jacked up the front of the vehicle so newly added sealer will run to the back of the tank around the bracket. Has anyone here had success with this approach? Am I really out a lot if it doesn’t work and I have to pull the tank?
I replaced the original steering column bracket with a 31 bracket. The tank is drained. I read another post recommending rinsing with wax and grease remover and then a final rinse with Acetone. I have these products but am wondering if either or both will destroy the liner I would just as soon leave unmolested?
