How is the most accurate way to check the toe-in on a model a? I have heard"read about different ways"
1. Mark the tires and use a tape measure.
2. Use a spring loaded curtain rod.
3. Use the string method, tie strings to the rear wheels, run up along the front wheels, Just touch the front and back of one, run up along the other one touch which ever side will touch first measure the other and see where you need to go. This is by far the easiest, but I wonder how accurate it is?
A 1/16" is a close measurement.
