So, after all this exacting effort to get the timing "exactly right", you start the engine and pull the spark lever down to where "that sounds about right"! Where is the timing at now? Don't know, do you![/QUOT
If the initial timing isn't accurately set , You really won't know where the timing is when you pull the spark down . If you don't know where the timing is when you retard the spark it can damage the starter when you try to crank it . If the timing is too advanced the engine will kick back and it still won't start . If a person thinks the problem is the battery and tries to hand crank the engine can kick back and break your arm if the timing is too advanced .This is a couple of reasons why exact initial timing is so important .
