Checking rear ratio
Was the other wheel locked from any turning? If it didn't turn at all, then you have a 2.75 rear end ratio, but that can't be.
Are you sure it wasn't 3 and 3/4 turns, which is the standard 3.78 ratio?
Tom, you are correct. Basically I can not count. I redid the test and this is what I got.
With the engine out and trans in 3rd gear. 2 complete turns of the tire gave me 3 and 3/4 turns at the input shaft.
In 1st gear it gave me 11 and 3/4 turns at the trans with 2 tire turns.
