rscardina Senior Member Apr 13, 2014 #1 I have seen this posted before but cannot find it now. Where is the best points to check generator output with a hand held amp meter?
jmeckel Well-known member Apr 13, 2014 #2 At the generator, on the side of the cut out that the wires hook to.
marc hildebrant Well-known member Apr 13, 2014 #3 Note, you will have to remove a wire and use the amp meter to restore the circuit if you are measuring current. Not so for voltage. Marc
