- City
- Winsted
- State
- Ct.
- Price
- in ad
Cheap parts, had about enough, will go one way or the other. $5. each.
-28-9 Instrument panel, needs plating,
-Valve cover with lower return pipe hole.
-Front motor mount, either style
-Hand crank
-Sedan rear fender braces
-Throw out bearing hub
-Clutch release fork
-Floor board plates, shifter or battery cover
-Shift tower with no parts for rebuild
-Shift or E-brake boots, $5. both
-Clutch or brake pedal, worn or pitted ribs but won't matter if pads are used
-Folding luggage rack for running board
-Front grease baffle A-2060
-Early style front grease baffle that have spacer to mount, with bolts
-Again all above $5. each plus postage in US. No pics. C A L L 860-238-4366
-Hand crank
